It is know bother at all, I may wander with my answers as I am suffering from a cold so do not hesitate to correct me. And as for calling me big names on PWs I am nothing and just a learner.
Ok answers to questions.
how does disc brake attach with hub? bolt on? or some designed surface?
The disc is just attached to the hub usually by nothing more then the four bolts that attach the wheel, so you remove the wheel the discs can be pulled off to once the calipar is move out of the way. On some cars it is screwed to the hub using 2 or more screws, usually on earlier cars or on some German cars. Nothing special attaches them. The attachment as simple as placing it on the lugs as shown in the pics.
how does brake booster work for rear brakes? same as for front ones?
yes same as the front ones, that is if the car comes equipped with one.
does it need two boosters... obvisouly not. bigger brake oil bottle...... i feel no. same booster can work for two pairs.
No one booster is good enough but I think you are talking about the Master Cylinder not the vaccum assisted booster. Yes same equipment will apply but you can. The brake distribution is in the Master brake cylinder itself so no need of any external device unless you think there is a need for it.
