i personally asked priced of rear curtain for my car, cost should be similar for yours, it was 75000rs, it will also require a new rear parcel shelf, this is for the original mercedes power shade, sides curtains for back seats you can get from shahnawaz price 45000rs they dont come powered
parktronic should be above 1.5 lac, its not a cheap option from factory even
back view camera would only work if you have the full Command Navigation system do you have that? or do you have the small lcd display behind the door in the centre console
original daytime running lights would be hard to find and they dont come blue as far as i know from factory. they also wont fit to your car as you have foglights, i think theres a option for daytime running lamps in the convenience menu in the instrument cluster, it will turn your high beams on at a low intensity, i have that option in my car,
there are after market generic ones but real daytime lights have a control module too and would also require messing with the wiring which is not a good idea. in your car they would go in place
i am sure about price of rear curtain you can get it form INH, rest i have tried to answer best i can
