I understand you both, that is why I have been trying to search for complete new wiring harness for Suzuki Khyber as the local mech's electrician has made a mess out of it. If one opens the hood or the dashboard, its impossible to understand how the jougars have been done and what is going where. So far I have been able to only re-make the horn wire harness.
The only thing stopping me is where to find good quality DC wiring. I know the best brands for AC wiring but since DC wiring is different and these Manufacturers I know don't make DC wiring so where to find in Karachi and what brands.
What are the gauges of cables that go to to Self Starter motor, generator, fuse box. Both battery grounds to gear box and engine. Also the gauges for all other misc wiring. Radiator fan motor wire. To distributor.
Also I want to buy good quality grips and plugs; where can I find them.
The reason I want to do this because if I disconnect my radiator fan motor, i notice increase in engine response (revving faster, smoother idling etc). If I turn off my headlights, other lights brighten etc. The other day I just cleaned the battery terminals and the above improved significantly. I once gave the car for overhaul + denting + painting and all the wiring got further messed in addition to the previous jougars. Most of the cabels in the car are not genuince and apparently low quality wires.
I consulted two electricians and they asked for 6000 rupees (3k for "saman" and 3k for labour) for complete wiring change and grips etc etc. I want to do it my self since no company is making wiring harness for Khyber and I cant trust these electricians and I better do it my self If I get to know:
The gauges of wires
The brand of wires
The place to get good quality grips as mostly parts shops have very cheap quality ones
If possible some body has a picture of wiring harness of Khyber (this can even be done from another Khyber which is still running in original setup)
Making harness is easy if you one has the above as I recently made horn harness by punching and then soldering the clamps at the wire ends. All you have to do is take the wire and the grip to soldering expert and its 5 rupees per solder and the heat shrink is cheap.
