AA,
a) In case the car is still under Warranty: the Dealership should look into it and provide a fix.
b) Earlier had experience of oil leak around gear box. (However it was a Suzuki)
Although symptoms were similar, and leak source was a mystery.
Mechanic used bright light to identify source oil 'spill' : turned out to be plastic cover, near top of gear box (locally called 'tickly'). Long time to fix it, but not costly. (once again, that was a suzuki, not 1zr-fe)
Hoping it helps.
Regards.
