Thanks again for your reply..
Here is a quick gpt resonse:
The term "Italian tune-up" is aimed at improving engine performance, particularly in high-performance cars that spend too much time at low speeds, short trips, or idling conditions. The idea is that by driving the car hard for a period (often at high engine speeds and under heavy load), you can help burn off carbon deposits, clear out partially clogged fuel injectors or intake passages, and generally "exercise" the engine’s full range.
So, if I drive at around 110 km/h on the motorway for about an hour and occasionally rev the engine harder than usual, will it achieve the effect of an 'Italian tune-up'? Also, should I even bother doing this before I notice any performance issues with my car, or is it something best reserved for when I actually encounter engine problems?"
