I looked and i looked hard for it but couldn't spot it. Its been a while since i bought 2008 efi cultus. I am curious to keep an eye on gear oil. Anybody? Attach Pictures if you can?
No dip stick in Cultus
/ok so then how do we check the gearbox oil level
@ pwuser151666730740Bro, 10 years...............is a long time period. Change your gear oil with flushing the system. You can use TOTAL Gear oil; they are quality products
Where does the gear oil go?
I have got engine oil changed and power oil changed. Is this something different.
there is a drain and fill bolt on gearbox, you fill gearbox till it drips from fill bolt hole - make sure car is level when you fill - otherwise you will over or under fill - both are bad.
cultus doesnt have gearoil dipstick ... you'll have to get it checked manually .. there is a drain bolt down to the transmission ... desi mechanics check it from there they open it and it it drops from there then oil level is ok .. if not they pour in more ..
usually desi mechanics pour gear oil from the point where speedometer cable is connected into the transmission ...
i am using local gear oil it cost me 600 rs. I m not sure about the gear oil capacity but i think i is somewhere 2 - 2.5 litres
Please attach pictures, engine oil 2-2.5 liter dalta hya.
Can I do this myself? Ya mechanic ee keray ga?
nope man .. mechanic will do it .. you can not open that drain bolt under transmission it would be very hard and rusty and sluggish ...
