this used to be sold at caltex petrol stations. When it first came out it was called CX3. Mostly it didnt work in Pakistan due to the "d'rect pankha" on redieturr problem.
This product works with soaking and heat, meaning you run it through the system and shut off the engine when its at normal temperature, it will then clean everything out.
wont work on cold systems.
