Following are it's specs:
Type: Brushless.
Max. AC Output(kw): 1/1.2
Frequency(Hz): 50/60
Model: JF154
Bore x stroke(mm x mm): 54 x 38
Displacement(ml): 87.0
Max. AC Power(kw): 1.8(300rpm)
Right crankcase form: Crankcase cover
Overal dimension(L x W x H): 460 x 360 x 370
Net weight(kg): 30
Gross weight(kg): 31
Generator came with 6 month's warranty, 2 months warranty is still remaining. Have used it for 80 hours only. Gas kit is installed as well. It's a Chinese generator, Magma.
