What is the price of Mobil Super 10w-40 (4 Ltrs) ?
@fasfas<SCRIPT type=text/javascript> vbmenu_register("postmenu_2486662", true); </SCRIPT>
Sir its 1,750 Rs.
You can also get the petromin, they are making the same oil.
Guys vibration at idling means what?
Yesterday me and my frnd went to get an oil change in his alto, and even right after the change his alto was still vibrating with AC on at idle.
@iLLDuDe786<SCRIPT type=text/javascript> vbmenu_register("postmenu_2486597", true); </SCRIPT>
Sir check the idle RPM and set it according to the owner's manual with lights/AC off, on petrol, when engine is hot, ideal temperature, half way mark between C & H, also there is switch which keeps the RPM stable when A/C gets operational.
An afterthought is to check the engine mounts and after then rings and pistons of engine, if it is a high mileage car.
