I don’t have almost any off-road use so Which should i go for Toyota Fortuner 4x2 or 4x4? Is 4x2 underpowered or will it be ok for normal drive on normal roads?Thank u
A little under powered but depends where you are coming from. If you are upgrading from a 1800cc car to this then no issue. But if you already own a 2400cc or higher car then it may feel under powered. And if you opt for the 4x2 you will miss out on the new features like push start, powered tail-gate and many more.
Push start is there but power tail gate, 4x4,differencial lock, welcome lamps, door lamps, silver side steps isn't present in petrol version.
