Use only distilled, deionized or demineralized water to replace the lost water in batteries because using tap or reverse osmosis water from residential systems can produce calcium or magnesium sulfate crystals that can fill the pores and coat the plates. In an emergency, use rain water because rain water does not contain calcium or magnesium.
Add Only PURE Distilled Water To The Battery: When you need to add liquid to your battery's electrolyte solution, only add pure, distilled water. Adding anything other than pure distilled water to the electrolyte will introduce impurities that will cause adverse chemical reactions and interfere with the normal functioning of the battery.
