3rdly, if you object that why Pakwheels is selling it, then Pakwheels has a service "Pakwheels sell it for me", in which they 1st inspect the car, and if it passes a certain criteria, then it is declared as Pakwheels certified, otherwise inspected, and in case of used JDMs, auction sheet is also there.
Anyone can approach Pakwheels to sell his / her car, and Pakwheels can accept the offer, even if the car is accidented (as its all Business), but YES, issue will definitely be there, if they do not inspect it, if its a used JDM then auction sheet is not there and is unverified, and whatever the potential seller tells them, they add it in the description, and when a buyer buys it, and its later found that car is accidented, then they back out and do not support him.
The report is there, which is clearly a warning directly / indirectly, that car is not worth buying, and a potential buyer should stay away from it. But from Business point of view, its fine. At least they re not deceiving anyone, neither the buyer, nor the seller. If car is accidented, then it is accidented, and buy at your own risk!
