I have problem with my honda civic 2006 .When ever i press the brake the abs active on less speed and car skid on 20 KM/H. I have change the brake pad but problem is there. If i am driving on 40 km/h and press the brake the will not stop at the same spot and it skid and stop after 10 or 15 feets. Can anyone explain the issue.
Thanks in advance.
How hard do u press the the brakes?Wht do u mean by Skids?
Cars dont stop on a dime
Check your tires. And don’t press brake pedal like a maniac.
check rear disc padspoor discs at rearshift load to the front of the car and brake lock engages
( considering your tires and tire pressure is ok)
Clear sign of weak survoy cylinder... Once it gets weak people adjust it to max level & it engages abs early... Facing same problem & bought a new survoy cylinder. Now it's perfect
