Originally published at: https://www.pakwheels.com/blog/replacing-car-battery-daewoo-battery-good-idea/
Your struggle to keep a nice-looking car doesn’t end at its purchase. The real deal occurs when you have to maintain the car which requires a lot of time and attention.
Among all the important car parts, the car battery is the most important yet most overlooked part. As the weather changes and winters approach, the cold temperature makes the condition of a battery worse; so much that you might need to replace it. Here we have outlined some of the reasons that why replacing your car battery with Daewoo Battery can be a smart move.
100% Maintenance-Free Battery:
Our hectic routine makes checking car battery's water level more of a hassle, and most of us tend to forget keeping a track, which can result in damaging the car battery. To counter this, Daewoo Battery offers a complete range of 100% Maintenance-Free Batteries. Just get it installed and be hassle-free with no maintenance. Moreover, the battery doesn’t get affected by low electrolyte issues, which can permanently damage the life of the battery. Thus, offering longer life as compared to other batteries.
Quick Engine Start:
The most critical factor that adds to the quality of a battery, is its ability to start the engine in cold weather and that is measured through CCA (Cold Cranking Amperage). High CCA helps a car engine start easily during extreme cold. Daewoo Batteries have the highest CCA as compared to other brands, which is measured with the same AH of a battery.
Ready-to-use Batteries:
Long gone are the days when after buying a battery you had to wait for hours before installing it in the car, since it had to be first filled with electrolyte and then charged at the retail outlet, and all of this used to take at least 2 hours of waiting time.
Daewoo Batteries come pre-charged from the factory with best quality electrolyte. Just remove the battery from the box, install it and drive away.
Battery Health Indicator:
With Battery Health Indicator located on top of the battery, everyone can check the health of the battery easily. If the indicator shows green colour it implies the battery is in perfect condition, if it’s white, the battery needs charging and in case it shows red light it implies that the battery needs to be replaced.
Finest Korean Technology:
Daewoo Battery is manufactured with state-of-the-art Korean technology, under the supervision of Korean experts. Daewoo’s 100% Maintenance-Free Battery is reliable and meets international quality standards, which can give you higher performance and longer life.
One-year Replacement Warranty:
To ensure your peace of mind, Daewoo Battery comes with a One-year Free Replacement Warranty. Even if it’s the last day of your warranty period, you can get the battery replaced without paying extra as per the company’s policy.
