Hi,
For brand new engines definitely you will not have problem, it comes when your parts become older, there is also a spring behind tappet tips and you can understand after long time springs and other parts would not function same way.
I had problem with starting earlier, Auto Elec changed the Self Starter bushes, after that self performance improved, I also got Relay (cutout) installed with Self Starter to improve current supply. 2nd, Difference came when I recently used Sludge Cleaner to remove sludge/wax from engine and changed the grade of oil i.e. from 20W-50 to 10W-30. Nowadays I start on 1st self in morning on CNG. You know oils below or equal to 10W are good for cold cranking engine and less wear of engine as oil with low viscosity quickly pumps to parts. but upper grade should be >=30 mentioned above.
Check the injector nozzle of CNG, if it's not in good condition change (means mechanic would check
) At a pressure of 120 there would be oil in Cylinder I think.
I drive 115 KM daily and getting 23~25 KM/Kg, mainly 4th gear
. Try full paddle to come out of 1st and 2nd gears quickly. it's 1990 Swift/Khyber.
