I think this task is beyond your scope. Study it a bit then make your decision on how to make it work or get it worked on (meaning be informed so you can measure the workmanship being recieved)
The expansion valve is T shaped in your car rather than the H shaped one used on modern corollas. Installing the H shape requires no skill, T shape requires brains and skill, make sure mechanic understands such.
Forgetting to insulate the T shaped valve will result in bad working, same with installing its sensing bulb wrong.
