My Mehran bonnet spray nozzle leaks water when car is parked after a drive for a short while.Leaves a long water streak each time, which gets annoying to clean again and again.
Is there anyway to stop this?
Change it.
i guess, u r missing the valve installed behind nozzle, else it wud b stuck open due to water contamination particles, check n replace
a replacement will be the only option i believe
The container lid for the fluid didn't have a hole in it, so it was coming out the nozzle on the bonnet
Creating a hole solved the issue
