It means diagnosis was not correct.
A Gasoline engine needs 04 things for its optimal performance:
- Air (Air Filter, Throttle Body, MAP / MAF sensors, EGR, etc.)
- Fuel (Fuel Pump, Fuel Filter, Fuel supply lines, fuel injectors, etc.)
- Spark (Spark plugs)
- Compression
If any / all of these 4 is bad, engine will misbehave.
Also check for Catalytic Converter. It might be choked.
