How to remove wiper blade streaks on the windshield. Ihave recently changed the blades but streaks are there.
I saw a video where the person used wd-40.. can it be used???
if those are not deep scratches, add vinegar to a spray bottle 25:75 ratio (25 ml vinegar 75 ml water) soak the screen leave for 10 minutes. clean with running plain water and wipe dry, streaks will start to diminish. repeat till screen is streak free.
Get It buffed from windscreen polisher as there is no solution.I bought Corolla 2015 90% visibility was compromised got it polished and now 99 % visibility improved.
No no you didn't get my point, streak only appear upon wiper movement, and vanish after few seconds. What's the solution for that.
There is no visible streak on the windshield
Your glass needs cleaning as @capsat mentioned
Clean it with vinegar solution,
