I've got a new wagon R with just 600km on odo. My cars starts to wobble when I reach the speed of 65 and ends wobbling at the speed of 80. Wheel alignment, balancing and air pressure is all normal. Why does it happen?
It IS wobbling.
Sorry?
i too facing the same issue and i did the same like wheel alignment,balancing but it still wobbles
No,it's not the stability of the car
Sounds like a tire problem, a bad batch from Suzuki perhaps? Get the tires inspected.
This is a common problem and no amount of wheel balancing, tire pressure, or alignment solves it. It has to do with the stock tires that come with the WagonR. You will need to replace them with better tires for a smooth wobble free drive.
tire replacement comes with the cost and that is economy.It will effect fuel economy.
