why did you exchange the brake fluid in the reservoir?
because race car
So when I bleed all corners at the end, new fluid is drawn through the lines rather than the old fluid.
Subscribed!!
Now for the front brakes.
The fronts are not too bad, the rotors and pads having been changed once previously.
Remove caliper.
Remove rotor.
Install new rotor.
Install new caliper.
Transfer the brake line over.
Load the caliper with pads.
Pads installed.
This side done, repeat on other side.
Then bleed all four corners and torque lugnuts to 100 lb-ft. Recheck brake fluid level and lugnut torque after a few days, just to keep an eye on things. Drive gently for the next couple hundred miles to bed in the new brakes.
Done.
How did you bleed the brakes? I am only asking since I think you went Solo
There are vacuum bleeders and other one-man solutions too.
Ohh yeah... forgot that you have stuff we dream about in Pakistan hehe Nice thread, fun and educational at the same time!
I am quite sure all the stuff I have is easily available there, likely even better there and at lower cost.
Where can i find this tool kit in KHI..?
Sent from my Desire HD using PW Forums mobile app
