Sheer Shah.
That means it would be used ???
Sent from my Desire HD using PW Forums mobile app
when you push the caliper pistons back into their bores, connect a pipe and container to the bleed nipple and collect the nasty one in it. No need to push it into the system.
marriot road near Jodia Bazar - lots of tools shops there.
why is your brake rubber pipe twisted? it will block out flow.
All new calipers too.
But you are correct, when I put new pads in old calipers, I open the bleeder first so the cruddy fluid is pushed out instead of into the lines.
Twisted? Nope. It just looks like it.
Next project underway .....
That's some good professional work right there
30 wheels and 50 gears
That's a lot for a hobby
The Corvette had its first problem today, it refused to start.
A new battery solved it. The original battery lasted eight hard years in service. $132 and five minutes. All fixed!
did you get your $10 back.. ?
I will get it back tomorrow when the old battery is returned for recycling.
excellent threadwho helps u while u do all this?
Sometimes my dear family pitches in, sometimes I do it all by myself. It depends on who is around or not.
The front tire on the FZ1 was getting worn so a replacement was done this afternoon.
On the center stand with a jack to elevate the front:
Mudguard removed:
Calipers removed:
Axle removed:
Breaking the bead:
