There is a problem with xli 2012. It hardly goes to 120-130 km/h even at 5th gear with accelerator fully pressed. Normally runs at 100 km/h. What would be the reason and whats the sol. Its odo is 240000 km.
Kindly get your clutch/pressure plates checked
what if its auto gear?
Xli never came in auto gear till 11th gen corolla facelift.
Xli 2014 doesn't come with auto, however check your air filter and spark plugs as well as I had faced similar issue on my 2016 1.3 A/T and the problem was with the plugs which got replaced and now working fine
yeah i know but generally pocha tha what if its the case with any auto car. btw Thanks
Sister what is the condition of Catalytic Converter (if its there) of your car?
Time to change clutch kit, parts brand exedy or Aisin ( pressure plate, clutch plate, thrust bearing ) change transmission fluid ( use toyota fluid or aisin fluid )
Aisin is OE for Toyota.
Clean catalytic converter
clean cat
There's no catalytic converter in 2012 model xli. They started giving it in 2013 with a special sticker on the rear screen mentioning this brilliant feature
It is there in 2012 models. I have owned it and got.it cleaned as well.
I had 2012 june Xli and it was without cat converter. It might have come in late 2012 then...
Get the CATCON cleaned. It will resolve the problem. Which city are you located ?
i have a 2011 facelift xli and it has a cat converter
That is not possible. You must be mistaken or your car must be altered in a certain way.
Here is the proof since people don't believe until they are provided with proof.
Here's the link from where i cropped it from.
Kindly have a look at the date at the end.
we're not here to argue. i know it is there as i got it removed bcz of the same problem. I'm trying to help the guy as i have already suffered with the same problem so plz don't confuse him and let him get his car fixed. i'll be really obliged. thank u
It's not there in 2011 model. Period. Rest, you can figure out how it came in your car.I am also here to help. If he knows his car model then knowing this might help him.
