so time junoon right foot rest touches gear lever(shifter) due to this gear stuck and as it stick with the gear lever it also causes the vibration try this if your feel vibration ask any mechanic to tight the nut which holds foot rest and bhai bike k darshan tou kardo
loo g hazir ha ... drshan kr lo red chilli ka..
I am in love of your bike
hahahahhaha....
euro_2 bhai ab tou experience share karo do
[QUOTE=saboor73;4594522]euro_2 bhai ab tou experience share karo do[/QUOt
till now bike is good .but jo feel keya vo share kr diya vibration nd gear issue.. rest is fine comfrtable rid..
what about power of the bike?????????
Foot rest k bolts tight nahe hein sahe sy. Ya free ho gae hein. Spring washer laga k tight ker dein ya isi ko thora sa tight ker lein sahe ho jae ga aur vibration nahe ho gi. Basically loose joints ki wajah sy foot rest mein vibration hoti.Aur jo gear ka issue hey us ki 2 3 reasons ho sakti hein . Ya to gear worn out hey. Means previous user was not careful. Wheelie type stunts etc. Or. Clutch setting thori loose hey clutch wire thori aur tight ker lein and then check kerein. Engine oil time per change kerein aur 20W-50 grade use kerein.
power k bary m kuch ni kah skta .... jld he lagy ka chakkr villg ka to lg pta jy ga.
hmmm... check krta hn sb kuch.. is m 70cc ka plug lgta ha ??
yes 70 ka plug......btw thanks for reminding me i also face same issue of footrest they dont meet in a line one is back and one is forward type of thing will post pic tomorrow or btw euro 2....to polish the indicators i learned a tip from youtube that some toothpaste should be applied this tip worked for me pretty well and 1 more thing this gear lever is quite longer than 70cc gear lever so you have to press upward from frount with the top of you shoe and from going from second gear to 1st gear it takes a bit of force too so i use the front bottom of shoe and press on the back side of gear lever i dont know if you would understand will make video too if i can and lastly congrats for new bike mashallah looks very good
self delet...
thanks. i can unterstand..
did tighting of footrest bolts fix the problem of vibration?
nope.. vibration is still there..
one question more.. engin oil capsity in junoon.. ??
800ml. but still not 100% sure good question
800ml(0.8l)
junoon valve clearance ??
https://www.pakwheels.com/forums/bikes-3-wheelers/190249-my-new-yamaha-junoon-yd100-7 2nt comment ha bahi found this using google...and just read it over and it looks like the model hes got has got very very bad quality compared to our original Yamaha
