@vamsi i talked to kamran,s bro he told me that kamran been shifted home.he is good but in lil unconcsiousness
Excellent...thanks for the good news...give him my regards when ever you talk to him...
Our prayers are with him.Inshallah he will recover soon.
@RX115 today i tuned my bike yb100 from Yamaha service dealer and runs better than before but in 3rd gear 50 to 60 km/h speed the engine sounds like it is in 1sr gear and miss fires but when i increase the speed on 70km/h its works good and also in 4th gear autolube is also working so tell me whats the problem?i told to the mechanic but he said " theek a pae theek a do din chala theek ho jai gi"
guys i use to have a yamaha 100 without modification i did 120 km and after modifications it did over 130 km/h . if a 100cc 4speed bike can dothat then rx 115 should do latlest 140 km ..
lol RX wont needs modifications...its already modified by japs.....a stock RX115 easilly touch 150/kmh and its so easy to take it to 150/kmhu should try a avg bike(rx) then i hope u will not need any answersjahan tak bat hay yb100 ki to 110/kmh tak to main ne suna hay or exp bhi kya hay but 120 pehli bar sun raha hon
@RX115 i have decrese the autolube level and bike is ok now and i agree with you k yb100 new max 110km/h tak chalti hai i have 2010 model and modified karne k baad k pata nahin
@RX115....my present rx115 is doing 120kmph. will rebuild it soon...hoping to take it to its top speed to 150kmph.
its really good news.......asal main hum jab tak dhoain k badal na dekh lain humaraiy mechanics ko tasali nahi hoti but in real smoke wud be invisible in lower rpms.....and only does exisit in thin smoke flare at mid range throtle....check out motoGP 125 RACE......FOR REFRENCE
sure
@RX115 plug color is brown now and its dry smoke is invisible in lower rpm jab se li hai aaj bike 105km/h tak gaye hai pehli bar
@ALI It will improve more than this
top speed dependes on engine condition,lube oil, 2t oil, petrol,air resistence,road resistence,weight, air pressure in tyres if all these are good then the bike may be go on top speed
@RX115 what is the main jet size u are using?. Is it #130?.
today il share pics of my black rx135 and silver rx115 to night P.M if there is any get 2 gather in karachi! i would love to join..people say why do you like rx so muchjo baat rx may hai kis may nai
@Faheem @RX115 what is the main jet size u are using?. Is it #130?whats this aor jet change karne se kya hoga?
currently i m using makuni vm24 (4tl) its 135,s first model carb the jet #is 165 and slide #2.0
first of all welcome on rx fanclubwe will love to see the kings
what are you talking about?
yamaha did intalled mikuni vm22 on rx115 this carb has 130#main jet.......slide size is 1.5 and pilot jet is 7.5 size.....larger the # in main jet increases the hole size of jet....if u do install larger jet then needle and tube combination does also required for prper performance
