Specification
* Engine: 2-stroke 135cc air-cooled engine
* Cylinder arrangement: Forward-inclined single cylinder
* Displacement: 133 cc
* Max power: 20 PS (15 kW) @ 8,500 rpm
* Max torque: 1.85 kgf·m (18.1 N·m) @ 7,500 rpm
* Max speed: 180-190 km/h
* Bore x stroke: 56.0 x 54.0 mm
* Compression ratio: 7 : 1
* Transmission: 6-speed return
* Clutch: Multiple-disc, wet manual
Engine Year: 1998
Engine Condition: Perfect and with Soundless Internals. (Plug and Play with no maintenance) Serviced with new/original piston and new pressure/clutch plates. the engine can be bench tested/started on request.
Engine Warranty: 2 month return policy applies if the engine performs below potential.
Parts Included with the Engine: Original Rxz135 Carburetor, Charger, Plug Coil with CDI. In layman terms, you will get everything that you need to fire this engine up.
Engine parts availability: All servicable parts of the engine are available and in Stock.
Invoice of the engine will be provided so that the engine can be registered on the motorcycle papers of the potential new owner.
Chassis compatible for this Engine: Rx115, GTO, Yamaha 100 (only recommended if the owner installs a front disc brake setup) Please note that the 3 engine mounting points will need to be modified slightly to compensate for the engine in almost all Chassis, If done correctly both the stock and this engine can be installed on the users preference and without needing any further modifications.
Price: 17,000 Rs. It is exactly what i have in the engine.
Shipping Possible via Daewoo service
Any Questions please email.
