Yamaha MT-09 is a whole new concept in sport bike design. With a compact new chassis and high-torque 3-cylinder engine, this new generation performance machine is designed for riders who appreciate character and soul.
The beating heart of this new kind of animal is a lightweight 850cc 3-cylinder engine that kicks out a wide band of raw, linear torque giving outstanding acceleration that gets your adrenaline flowing.
And for agile handling this dynamic new naked motard-style bike is equipped with a compact aluminium chassis and upright riding position that make light work of everything - from weekday urban riding through to Sunday morning blasts.
SPECS:
Engin
Engine type: liquid-cooled
Displacement: 847 cm?
Bore x stroke: 78.0 mm x 59.1 mm
Compression ratio: 11.5 : 1
Maximum power: 84.6 kW (115PS) @ 10,000 rpm
Maximum Torque: 87.5 Nm (8.9 kg-m) @ 8,500 rpm
Lubrication system: Wet sump
Carburettor: Fuel Injection
Clutch Type: Wet
Ignition system: TCI
Starter system: Electric
Transmission system: Constant Mesh
Final transmission: Chain
Chassis
Frame: Diamond
Front suspension system: Telescopic forks
Front travel: 137 mm
Caster Angle: 25?
Trail: 103 mm
Rear suspension system: Swingarm
Rear Trave": 130 mm
Front brake Hydraulic dual disc, ? 298 mm
Rear brake Hydraulic single disc, ? 245 mm
Front tyre 120/70ZR17M/C (58W) (Tubeless)
Rear tyre 180/55ZR17M/C (73W) (Tubeless)
Dimensions
Overall length: 2,075 mm
Overall width: 815 mm
Overall height: 1,135 mm
Seat height: 815 mm
Wheel base: 1,440 mm
Minimum ground clearance 135 mm
Wet weight (including full oil and
fuel tank)
188 kg / ABS 191 kg
Fuel tank capacity 14 L
Oil tank capacity 3.4 L
WE hope to see these machines in PAKISTAN in near future in sha ALLAH
