Its heating up because he has tightened the the valve rocker assembly, as a result the tappet noise must have been reduced, torque would have increased a bit due to tighter compression but this results in the engine getting warm very quickly, i have tried this with my CG last month.
What you should do:
Have the valve clearance readjusted (a bit loose), somewhere near the factor setting with which it originally came with.
