I purchased YB-125-Z. I am facing the same issues which are mentioned above following issues:
Raat mai bike park kerdo or subha start kerney ki kosish to start hotay k sath hi off hou jaatee hai but I adjusted RPM as per my own it is working fine but I went to the service center they adjusted as per company so issue is starting again.
Bike slips on applying rear breaks. I am still in Break-In period. So in any case, I don't go above 50 Kms/hr and 4000 RPM. Still, on applying EMERGENCY breaks, the bike always slips. Is it the rear tyre that needs to be replaced or something else? By default, Service tyre is installed. I am maintaining the Yamaha recommended Air pressure in both Tyres.
Kindly give suggestion(s) and advises.
I copied question from above because I am facing same two issues.
