Asslam o AlaikumHope you all will be fine.I have Yamaha YBR-125 since 2.5 years. For the past 2 3 months i'm facing an issue. When I speed up the bike above 60-70km/h the front of the bike and handle bubbles/shakes/vibrates alot. Has anyone faced this issue? Is it due to shocks? Or do i need to change tyres? Please guide. Thanks
Its a motorcycle, not Cocacola. So, its wobbling.
It could be due to the rim. Did you hit a pothole hard?
You should spin the wheel and see if there is any noticable bend in rim on either side of it.
Bad shocks could also cause this issue.
Walaykum ussalam dear At the most of times puncture wala did not insert tyre properly inside rim from sides you have to go to some puncture wala & ask him to apply oil on tyre sides & re fit it INSHA ALLAH you problem will be solved
