Rear brakes doesn't help much .what can be done to make them better . Thanks
because you are not suppose to use rear brakes only for heavy braking front brakes are the main brakes when it comes to bikes and we don't have the proper training to balance front and rear brakes in our daily commute
U have to use a combination of engine, rear and front brakes.
So that means , nothing wrong with the brakes.
No. Many bikes' rear tire skids when u only use the rear brake.I have to use both front and rear in order to stop.
Rear brakes are to be used in combination with the front brakes. If u press them in isolation, bike will skid like anything
rear brake must be used in combination with the front one, but the quality of yamaha rear brake is not as good as suzuki or others.it gives a hard feeling and feels like drum is slipping when rear brake is applied.
I have taken my 2019 YBR G to everywhere. Mountains, good roads, bad roads. It has one of the best brakes amongst local bikes.
it depends on the user choice i guess, i have used ybr in last 04 years then gd110 for a short time.I have noticed that there is a difference in both the products when it comes to rear brake.
I never said that your rear brakes are fine .... do get them checked if the pads are worn out please do replace them
and for future use a combination of front and rear brakes and engine braking to slow the bike down ..... there are plenty of youtube videos for where you can learn
