i'm already having a complete set in pakistan but i like their clour as they look damn good!
hahah same feelings for the previous owner idk WTH he did with remote
ahh thanks to Allah you got it ;D
it might be of timing belt, bearing or any pulley. Better get it checked from some mechanic and see what he says
oops my bad
Tool hunger never ends
Hahahaha.. No worries
u should find out the price of rear new led lights and center console it looks hot in silver color , if you find out share price here too
i went to two mechanics who told me that this is normal gear sound, today morning i also felt like this sound is coming from right side where the belt is not the left side so it may be the sound from belt which only comes during acceleration
right side bearing can also be the ulprit but it has nothing to do with accelerator, get the belts of the ride checked ASAP!
initially i thought this sound is of bearings so i changed all of them except front left what is the cost of belts if i replace them
are you talking about LED backlights or number plate lights?
the center console is also on my list
brother the belts are not expensive , i bought the AC compressor and Denmo(dont know exact name) for around 800, the timing belt will also be around 500rs
An image may be helpful here.
Recently installed leds on my cultus vxli on num plates and the results is awesome.was a pretty easy diy job.total cost was 100rs
Sent from my iPad using PW Forums
What type of led? Smd or normal? Can you share pic of led and after installation?I plan to install in reverse light so its more bright while reversing
Installed smd strip in a pretty neat way and it also really helps while reversing.will upload some pics as it gets dark.no need to update the reverse light as it is already bright enough.
Can't wait to see pics. I will install smd strip in center brake glass to glow with brake.
The current lights coming in every suzuki cultus with center console
Can anyone tell me how much will the rear lights and center consoleCost
@nasirjavaid @nfsmostwantedDo say MashAllah
