What the actual.. f! I went to punjab car AC to get mine fixed and they said it only needs cleaning and we will add complimentary gas (it was only ten points low) and cleaned the outer grill as well, AC is now Brrrr.. even in mid day, all for 2000. Keeping in mind i never serviced the AC ever since i got the car in dec-2015 and i have no idea how long ago the previous owner got the ac serviced.
Edit: I’m having a minor alternator issue, it’s not fully charging the battery or gets below 12V under full load (AC, Fan at speed 3, Headlights and Radiator Fan) when standing at a stop i have to turn down the ac fan on lowest speed so the voltage stays above 12V , without any load the alternator works perfectly and shows 14.2V, i had starting issues at first but i replaced the battery and never had the same issue again since six months, but morning voltage is 11.6-11.8V nominal, it should be atleast 12.4-12.6V iirc, any suggestions cultus gurus.
