From Zic Webpage
ZIC XQ 5W 40
ZIC XQ | ZIC LUBRICANTSZIC LUBRICANTS
(API SM/CF) CF is for diesel or also called Compressor Engines. Typical CF Compliant Oils require higher detergent levels to be able operate in a Diesel Engine.RECOMMENDATIONS/SPECIFICATIONS
API SM/CF, ACEA A3/B3/B4
- Approved by VW/AUDI 502/505, MB-Approval 229.5, BMW-LL-01, PORSCHE A-40 (except Cayenne V6)
- Meets and exceeds VW 505.01, Opel GM-LL-A-025, Opel GM-LL-B-025, Renault RN 0710 specifications.
TYPICAL PROPERTIES
[TABLE="width: 1"]
<tbody>[TR="class: first_head"]
[TD]SAE GRADE[/TD]
[TD]5W-40[/TD]
[/TR]
[TR]
[TD]API Grade[/TD]
[TD]SM/CF[/TD]
[/TR]
[TR]
[TD]Specific Gravity, 15?C[/TD]
[TD]0.85[/TD]
[/TR]
[TR]
[TD]Kinematic, Viscosity, cSt, 40?C[/TD]
[TD]86.7[/TD]
[/TR]
[TR]
[TD]Kinematic, Viscosity, cSt, 100?C[/TD]
[TD]14.4[/TD]
[/TR]
[TR]
[TD]HTHS Viscosity, mPa?s@ 150?C[/TD]
[TD]3.8[/TD]
[/TR]
[TR]
[TD]Viscosity Index[/TD]
[TD]173[/TD]
[/TR]
[TR]
[TD]Flash Point (?C)[/TD]
[TD]240[/TD]
[/TR]
[TR]
[TD]Pour Point (?C)[/TD]
[TD]-42.5[/TD]
[/TR]
[TR]
[TD]Total Base Number (TBN)[/TD]
[TD]9.0[/TD]
[/TR]
</tbody>[/TABLE]
Zic OW 30 - Gasoline Engine Oil with better flow characteristics in low temperature environment.
ZIC 0W | ZIC LUBRICANTSZIC LUBRICANTS
- API SN/ILSAC GF-5
- For hybrid vehicles which requires 0W products.
TYPICAL PROPERTIES
[TABLE="width: 1"]
[TD]SAE GRADE[/TD]
[TD]0W-30[/TD]
[/TR]
[TR]
[TD]API Grade[/TD]
[TD]SN[/TD]
[/TR]
[TR]
[TD]0.84[/TD]
[/TR]
[TR]
[TD]52.52[/TD]
[/TR]
[TR]
[TD]10.06[/TD]
[/TR]
[TR]
[TD]HTHS, Viscosity, mPa?s, 150?C[/TD]
[TD]2.90[/TD]
[/TR]
[TR]
[TD]175[/TD]
[/TR]
[TR]
[TD]Flash Point, (?C)[/TD]
[TD]240[/TD]
[/TR]
[TR]
[TD]Pour Point, (?C)[/TD]
[TD]-47.5[/TD]
[/TR]
</tbody>[/TABLE]
Zic A+ 5W 20
ZIC A+ | ZIC LUBRICANTSZIC LUBRICANTS
- Suitable to use in CNG/LPG engines
TYPICAL PROPERTIES
[TABLE="width: 1"]
[TD]SAE GRADE[/TD]
[TD]5W20[/TD]
[TD]5w-30[/TD]
[/TR]
[TR]
[TD]API Grade[/TD]
[TD]SN[/TD]
[TD] SN[/TD]
[/TR]
[TR]
[TD]0.85[/TD]
[TD]0.85[/TD]
[/TR]
[TR]
[TD]52.3[/TD]
[TD]67.14[/TD]
[/TR]
[TR]
[TD]8.9[/TD]
[TD]11.2[/TD]
[/TR]
[TR]
[TD]159[/TD]
[TD]160[/TD]
[/TR]
[TR]
[TD]Flash Point ?C[/TD]
[TD]230[/TD]
[TD]230[/TD]
[/TR]
[TR]
[TD]Pour Point ?C[/TD]
[TD]-40.0[/TD]
[TD]-40.0[/TD]
[/TR]
</tbody>[/TABLE]
From the above info it seems while Zic A+ and Zic 0W 30 may have similar base synthetic oil suitable for Gasoline Engines but XQ seems to be from a different Base Oil and possesses different additive formula. Also read MSDS for additional info on these ZIC oils. But then you will not get any info on the actual additives used in these Oils and their quality / quantity and concentration which differentiates their service levels and also price.
