Dear PW Members,
I have a Toyota Vitz 2009 Model 1.0L 1KR-FE Engine. Few week earlier I have purchase ELM Scan device and i scan my car ECU with HOB Drive Demo App When i click on Diagnose Code I found out there is one code is showing in Pending Error Code heading and the Error Code is P1605 (See attached screen shot) I have accidentally press clear DTC button and now the error code has been removed from ECU and don't show up in HOBDrive Demo App. Now I have following queries.
1- What P1605 Error Code means?
2- What will be fault that cause this error?
3- How to fix that fault that cause this error?
Car: Vitz 2009 1.0L 1KR FE Engine
Device: ELM Device
App: HOBDrive Demo
Prob with my car:
I have found one issue happen with my car which infact Toyota dealership can't diagnose it and they said if that issue come infront of us then we can tell you whats the problem the Issue is when the car runs in slow traffic for an about one hour with AC ON and when i applied brakes with AC is ON then at one point there is some kind of noise coming from engine bay (i believe its sound of some knid of belt) and Car is stop in Gear D this happen when gear is in D and i applied brakes with AC is ON with about an hour.
4- Is it P1605 relevant to above mentioned problem
5- What will be the fault and solution of above mentioned Problem with my car
This is my first thread i have posted on PW.
