Great progress,
What colour have you decided to paint it,
I would advise you against going for a dark colour unless you're having it bake painted and have an excellent painter, even the best of painters here in Karachi can not give you a perfect mirror finish and there is usually a slight presence of waves on the body work which are more pronounced when you use a dark colour,
also make sure that the filler (bondo) is a very, very fine layer and the denter doesnt smack on an inch thick layer of bondo on the body to hide his imperfections,
make sure the vehicle is painted in your presence and supply everything yourself, i.e. the primer, filler, paint etc all ideally from the same company,
also use a Y2K paint and have it mist sprayed in layer to give you depth,
should look beautiful when completed,
I would also humbly suggest that you have the floors etc done prior to paint, once the car goes into paint the only thing remaining should be fitting back the engine/gear and the trim, interior and exterior,
also get the interior and exterior thoroughly cleaned before being painted and ideally ask your denter to use block sanding for the exterior to minimise waves,
love your car Mashallah and am eagerly looking forward to it being completed.
