fuel trim are the learned and immediate values that the ECU uses to adjust fuelling. aka long term fuel trim and short term fuel trim - the long term is learned over time and is used to adjust fuelling (it compensates for worn parts like MAF or O2 sensors)
the short term is immediate and changes at every start - the long term is stored in keep alive memory.
In my experience - MB 112 use a very sensitive MAF and it does wear out in about 125,000 kms - replacing it with a pattern part is not a good idea, only a replacement MB item or exact item from pierburg or Bosch works - they are not cheap. Same with the o2 sensors, they go weak and lazy after 125,000 kms. (shorter if they are poisoned)
If your fuel trims show a consistent addition of fuel at nearly all rpm range, your MAF is highly suspect, test the O2 sensor too.
the trims can be checked with SDS, autologic or even any good scan tool like a launch X431 etc. My little handy bluetooth can check them too.
