@Xulfiqar
Hi I own a Corolla altis 2010 had issues with it hope you can give a valuable and suitable suggestion thank you.
Auto Tranny their is a slight leak (not proper leaking or dripping its just a Emanate) and Transmission fluid is in good condition and up to the mark,I took it to Toyota Dealer the Technician told me not to worry just keep a close eye on ATF fluid,next time time on proper mileage when I will be changing ATF then we will fix it.
Cruise control is not engaging properly.It was working perfect but from last few months it does not hold the speed and the cruise lights start blinking,even Toyota guys don't have any idea.plz help.They used to say spiral cable is damaged i even changed it but it's of no use.
there's a DIG sound(Don't Confuse it with Tic Tic Sound which is due to compression of metal) coming from rear of the car,I am unable to point the main reason what is causing this sound?Car is having 235K Mileage.Checked shocks,Steering rack everything is fine.Is it from fuel pump or what ?
