@xulfiqar @naweed @syncview
Aoa experts :
Vitz, 2011 model, 60,000km
Its running at higher RPM than normal. Its Throttle Value was cleaned 1 weeks ago with Liqui Moly Throttle Value cleaner. (simply by removing intake hose, without removing throttle)
After cleaning, when started, its Rpm was higher than the normal.
Mechanic suggested to disconnect battery terminal to reset ECU and than start engine and run it for 5 to 10 minutes in idle. But after doing this, same problem remains.
Then he said drive car for 3 to 4 days, it will be adjusted automatically. But after running car for 400km in one week, same issue. Any suggestion or advice?
@xulfiqar sir
