guys im back !!!! i bought a daewoo racer GTi 99 model the front view is a cielo and the back part is a modified lights for racer i dont know if is been converted from daewoo racer gti to cielo looks and the interior is mixed up racer dashboard and floor.. the side panel and the light switch and power window buttons is for cielo... and the engine is 1.5 EFi SOHC G15SF ..
and i have a problem on it :
1.no speedometer cable - dont know if the racer cable would fit....
2.idling problem - tunning it to 700RPM the car is acting like im stepping the gas peddal (but im not) and REV it to almost 1700RPM-2000RPM... i already clean the IAC....still tunning it to 700rpm still have problems..
3.A/C - after tunning it to 800RPM (stable for idling the car)..when turn on my A/C the car drops its idling and make it stall or stop the enigne......
4.found out there is a leaking problem in my power steering
5.Alternator problem - making a sound like a loose metal
6.power window motors - windows are to slow going up but fast when going down..
7.black smoke and a smell of not well burn oil - already use a 1 can of super oil treament called WHIZ to stop the black smoke but i think i need to use 1 more can to treat the oil...
8.some led up lights dont come on before i start the engine the check engine ligth, seat belt warning light,ABS if i have one or been disable dont know where to find the wire connecting to it..
9.two connectors had not been use and i dont know where to put it...i will add the picture of the connector later...
pictures to follow guys...
