AOA fellow members
This time I am in trouble,
Car is not starting. Reason being No current from the coil to plugs.
Positive wire to distributor (Igniter) was broke, when i connected the two broken ends the car started, so to give it a secure connection , I opened up the dist. and soldered it to its terminal on the igniter instead of twisting & taping it. After that the car refused to start. No current from ignition coil to plugs.
Checked the following according to service manual
Ignition Switch - OK
Ignition Fuse - Ok
Current to the Coil - Ok
Coil - OK
Main cable (coil to distributor) - OK
Connections/wires of Igniter - Ok
Signal Generator - Ok
Rotor air gap (0.2mm) - OK
Rotor - OK
Igniter - Not checked
One more thing when I was testing , the negitive probe of my voltmeter was on the negitive terminal of the battery and with car switch on (engine OFF) I got 13V reading on the +ve terminal of the coil and same 13V on the negative terminal of the Coil, WHAT DOES THIS MEAN?
HELP ME OUT HERE GUYS
