71-74 CorollaOriginal Factory Options, Specs, Features, Etc.
Engines: K 3K 2T, 2TC
Body codes: KE10, KE15, KE16V KE11, KE17, KE18V, KE20,
KE25, KE26, TE21 TE25, TE27, TE28
Displacement: 65.7ci (1100cc) 71.1ci (1200cc) 96.9ci (1600cc)
Horse Power: 60@6000rpm 73@6000rpm 102@6000rpm
Bore: 75mm 75mm 85mm
Stroke: 61mm 66mm 70mm
STANDARD EQUIPMENT:
4-speed full synchromesh transmission
Reclining bucket seats with head restraints
Flo-thru ventilation
Tinted glass on 1600 (Wagon - windshield and door windows only)
Reversible key for door & ignition
Electric rear window defogger on 1600 series; 1200 series (N.Y)
Resettable trip odometer (all except 1200)
Heater/defroster with 2-speed fan
Tool kit and touch-up paint
Fold-down rear seat on station wagon
Spare tire recessed into floor of trunk (except wagon)
2-stage door opening
Padded armrests (all except 1200)
Cigarette lighter
Rear utility storage pockets (1600 coupe only)
Wall-to-wall snap-out carpeting (all except 1200)
White sidewall tires
Deluxe wheel covers (all except 1200)
Deluxe door panels (all except 1200)
Front disc, rear drum brakes (power assisted on 1600 series; S-5 and SR-5)
Unit body construction
Anti-theft steering column
Padded dash
Safety recessed door handles inside and outside
2-speed washer/wipers
Inside hood release
Passenger assist grips
OPTIONS:
Automatic transmission (all except 1200, S-5 & SR-5)
Air conditioning
AM radio (standard on S-5 and SR-5)
AM/FM radio
Stereo tape deck
STANDARD SAFETY FEATURES:
Side door guard reinforcement
5-mph front & rear energy-absorbing recoverable bumpers
Collapsible steering column
Fire retardant material for interior soft trim
4-way hazard warning flasher
Safety-interlock front seat belts
Standard rear seat belts
Break-away rear view mirror
S-5 SPECIAL FEATURES:
5-speed full synchromesh manual transmission
AM radio
Simulated wood grain console, shift knob, instrument panel and steering wheel
Tachometer
Separate gauges for fuel and water temperature
155 SRxl3 radial tires
Mag-style wheel covers
Sporty 5-speed tape stripe
SR-5 SPECIAL FEATURES:
AM radio
Fender flares
Simulated woodgrain shift knob, instrument panel and steering wheel
Full center console with simulated wood grain trim
Wide 175/70 HR x 13 tires
Styled steel wheels (5J x 13)
Tachometer
Front stabilizer and strut bars to help reduce body roll
FACTORY SPECIFICATIONS:
SR-5, S-5, 1600 Coupe, 1600 4-Door Sedan, 1600 2-Door Sedan, 1200 2-Door Sedan, 1600 Wagon.
Corolla 1200.
ENGINE:
Type: 4-cyl. in-line, OHV, 5-main bearings
Displacement: 1166cc
Compression ratio: 9.0:1
Horsepower: 65 hp at 6000 rpm (SAE net)
Torque: 67 ft/lb at 3800 rpm (SAE net)
Carburetor: Downdraft 2-barrel
Corolla 1600:
ENGINE:
Displacement: 1588cc
Compression ratio: 8.5:1 (California: 9.0:1)
Horsepower: 88 hp at 6000 rpm (SAE net)
Torque: 91.3 ft/lb at 3800 rpm (SAE net)
Carburetor: Downdraft 2-barrel, automatic choke
ELECTRICAL SYSTEM:
Battery: 12 volt, 50 amp/hr
TRANSMISSIONS:
4-speed all synchromesh:
Ratios: (1600 series) (1200 series)
1st 3.587 3.684
2nd 2.022 2.050
3rd 1.384 1.383
4th 1.000 1.000
Reverse 3.484 4.316
5-speed all synchromesh (S-5 & SR-5 only):
Ratios: 1st 3.587 4th 1.000
2nd 2.022 5th 0.861
3rd 1.384 Reverse 3.484
Optional Automatic 2-speed with torque converter (1600 series 2-door & 4-door Sedans):
Ratios: Low 1.82 Reverse 1.82 Drive 1.00
Optional Automatic 3-speed with torque converter (Coupe &Wagon):
Ratios: Low 2.450 Drive 1.000 Intermediate 1.450 Reverse 2.220
REAR AXLE:
Ratio: 4.222 (1200 2-door Sedan)
3.909 (4 speed synchromesh trans.)
4.100 (5 speeds and all automatic trans.)
SUSPENSION:
Type: Front: MacPherson strut, coil springs, anti-sway bar
Rear: Semi-elliptic leaf springs
STEERING:
Type: Recirculating ball
BRAKES:
Type: Front disc, Rear drum, Power brakes (1600 models only).
Diameter: (1600) (1200)
Front disc: 9.0 in. 7.87 in.
Rear drum: 9.0 in. 7.87 in.
TIRES:
Type: 4-ply rated tubeless
Size: 6.15Sx13 (1600 models)
6.00x12 (1200 2-door Sedan)
155SRx13 radial ply blackwall (S-5 Coupe)
175/70HRx13 radial ply blackwall (SR-5 Coupe)
DIMENSIONS AND WEIGHTS:
Wheelbase: 91.9 in.
Overall length: 163.5 (165.4 Wagon)
Overall width: 59.3 (62.8 SR-5)
Overall heights: 53.0 (Sedan)
52.6 (SR-5)
55.3 (Wagon)
Tread Width: SR-5
Front: 49.6 in. 50.0 in.
Rear: 49.0 in. 51.0 in.
*Curb weights:
1815 lbs (1200 2-door Sedan)
2005 lbs (2-door Sedan & Coupe)
2015 lbs (S-5)
2050 lbs (SR-5)
2050 lbs (4-door Sedan)
2065 lbs (Wagon)
Fuel tank capacity:
11.9 gal. (Coupe & Sedan)
10.6 gal. (Wagon)
Oil capacity:
3.9 qts. (1600 series)
3.7 qts. (1200 2-door Sedan)
Cooling system capacity:
6.9 qts. (1600 series)
5.1 qts. (1200 2 door Sedan)
CHASSIS/BODY
Unit construction
- Add 15 lbs. for Calif. models.
may it helps u
