Hello,
I have Grande 2017 facelift with 70k mileage. As per owners manual, its cvt oil needed to be changed at 55k while the fuel filter was due at 65k.
I am planning on replacing both.
I visited the dealership and they recommended the following for each item:
1) CVT OIL CHANGE
Dealership recommended that I change the transmission oil along with the transmission oil filter. For this they will open the chamber clean it, change the filter, drain the previous oil and add new one.
The estimate of they gave was around 25k including 6k in labour.
This was over my budget so I went to a local mechanic, he recommended to open the chamber, clean the filter with petrol and change the oil. Total cost around 10k
I would like your input on which option is better, the dealership is very expensive, but I do not want to ruin a 3.0 million rupee car in trying to save thousands. If the local mechanic option is OK what precautions do I need to take so he does not mess it up?
2) FUEL FILTER
The dealership recommended a change of entire fuel filter assembly with estimated bill for around 20k. Including 18k for parts and 2k for labour.
The local mechanic recommended to change only the filter within the assembly, which costs around 2k.
Is changing the filter instead of the assembly reliable? Or will it lead to problems in the long term?
I know its a long query, but I would be grateful if you can guide me on which route to take, as I am very confused.
Thank you
