Thank you, shall share more pictures in a day or so.
Thank you, the R3 model includes a 300-watt Bose audio system in surround sound, Bluetooth hands-free phone connectivity, Recaro seats, a revised rear wing, rocker-panel extensions, a stiffened front suspension crossmember, higher spring rates, firmer damping via Bilstein shocks, and 19-inch aluminum alloy wheels wearing Bridgestone Potenza RE050A 225/40-19 run-flat tires (which I don't like). But more importantly, the Renesis II includes a third oil circulation pump, putting to rest worries of oil-burning, engine compression dependability and longevity of the earlier models.
Another difference I felt from Gen-1 is, the R3 has slightly more grunt in lower RPMs, although torque remains the same in both variants. The Recaro's are a true definition of what 'body hugging' means and takes some time to get used to. Shall give a more detailed overview on the R3 vs Gen-1 after i've racked up some miles
