Asalamualaikum Everyone, I have been visiting this forum since I bought City 1.5 Aspire CVT back in December 2021. I have been using Yoko BluEarth (Es32) 195/65/15 from the beginning, since the stock tires were too narrow and got the Yokos in PKR 60K. However, now the car has been driven around 55k Kms and I feel that tires are worn out and does not provide the same grip. I have noticed that braking is not as firm as it should be and abs kicks in way too early, accelerating a bit hard also spins more than usual (tires have been regularly rotated and brake have also have been serviced as scheduled).
I have been researching which tires should I get and found out that same will cost me around PKR 120k and you also have a chance of getting bent tire. So, looked for the alternative in local and concluded that BG Thunder Max same size would cost around PKR 60k.
I wanted to get an opinion regarding grip noise and an overall review by anyone who has any experience with Thunder Max. Tips regarding adding grip to the yokos (so i can squeeze a little more life from current ones) is also welcomed.
