Thanks Hassan Brother for your time
I am from Mardan.I am a software engineer but also interested in electronics.
How do i find out which generation engine i have.
Correct me if i am wrong My IAC is working fine because when i start my car its rpm
is high from the normal and then slightly goes to normal as well as when i disconnect my IAC
Plug rpm goes higher and get back to normal when i plug it back.
Do i need to connect the ELS1 or ELS2 to the relay hot wire (On fan side) or the ground directly.
ELS1---------------------------------Fan----------------Hot wire------- (Relay)
One more thing when i disconnect my MAP Sensor Or IAC Valve i get a engine check light
but when i disconnect my water temperature sensor or my TP Sensor i get no check light / Code
and also when i disconnect my water temperature sensor there is no impact on my car what do
you think is there is some problem.
Hassan brother if possible please gave my your cell no.
Thanks.
