This is a "Marz" in LC80. Waist handbrake of LC80 is a joke. Dill ki tassali.
Why Hand Brake light is On
I'm located in Islamabad.
And yes, the facelift one has a 24 valve engine.
Yellow oil lamp is for low oil level warning, its sensor is like a toilet tank valve - check the sump you will find it - Replace the sensor - once it starts doing this and the oil level is correct then you need to replace the sensor (float) - the old 2JZ-GE also had this. But I would recommend a brand new one as all old ones would be scrap and wont work.
Change it next time you change the engine oil.
@tintin1 What about Radiator? (I guess, initially, there were some issues with Radiator, and it was not doing its intended function efficiently)
check brake fluid level and check the float switch wiring on it too - the brake warning lamp also serves function to alarm the driver if brake fluid level has fallen below safe level.
btw I hope you had the torque converter changed too as an imbalance on it can literally destroy the crankshaft.
Sure bhai. Just give me a day and I'll send you the pics.
Na karain sir. Aik hi spot Hai hum logon Kai pass enjoy karne ke liye
Rebuilding gives you 100% good result, but only if you have a rebuild kit with you.
Btw, make sure the vent is clipped on this new gearbox, otherwise it will ingest dirt too.
This sensor is bolted from the outside of the sump. It has a white 2 pin wire connector.
In toyota global catalog its cost is usd 230
