AssalamAlaikum Everyone, so as the title says I own a 93 B13 with cd17engine, It is a long story so please bear with me here..
Its very sad for me to tell you that the car is in very bad shape and has not moved in almost a year, the main reason of its being grounded was a problem with its wiring which made it unreliable, the car would shutdown intermittently and would not start and after some time it started and ran fine. to cut the story short no one here (Hyderabad) was willing to repair its wiring, so me being an Engineer (Metallurgist) and having sufficient knowledge in electronics started to go through its FSM and then finally took its engine wiring out and ALHAMDULILAH completely fixed it with 99% success last year and made a 300km trip without any problems... since then the car has not moved due to bunch of problems with it mainly lack of time and funds.
Now I have been planning its swap since its engine is one of its biggest problem, bear in mind I love diesel engines and cd17 is my favorite but since we do not have proper mechanics and quality diesel fuel here plus the engine has gone through so much so rather than rebuilding the diesel I wanted to swap a gasoline engine.
So in June/July 2015 started my research and wanted to swap GA series but then I saw some threads here of QG series and fell in love with the beast QG18.
So here we are now I need your precious advice on some questions whichare bugging me:
1.I want manual transmission is it easily available?
2.The main thing Manual transmission ECU and its pinouts for QG18?
2.why E-throttle is a major issue? Due to pedal or what?
3.If I get manual tranny then the hydraulic clutch will be easily installed or is it an issue in itself?
4.Fuel tank will be needed to change/upgrade? How fuel pump issue is best resolved?
5.Exhaust will be upgraded?
6.if you know QG Series prices in karachi please inform
rest will ask as the thread goes on
I am tagging the experts, please come and give your valued input also tag others I may have missed @Xulfiqar @star2 @SER_GTR @IsbCap @spectra
