Homework is same for
QG15de..
QG16 is very rare here. It's available in ethrottle mostly here.
Secondly you need to change axles, and install a new clutch plate set because kabli is 4/10 clutch plate most of the time and they clean it with petrol to make it rough lolz.
So then comes check if the flywheel is smooth. If not then Polish it.
Secondly if you get genuine manual transmission of QG15 it would be good for you.
Rest all the hectic thing is hooking up the wiring.
If it's three row ecu wiring manual available is in Russian but don't worry I've decoded it in to English completely.
Then comes engine should be leveled inside properly. Height should be leveled.
Then checking for thermostat valve because usually scrappies take out the valve.
When you'd be checking the engine do check for the cut pipes, belts, cracks on block, sensors should be properly working.
Wiring should be uncut, properly in the loom.
Likewise if you require any further help, keep posting here and experts will keep on helping out.
Sent from my SM-G360H using PW Forums mobile app
