Into centre AC went. Bohat zyada andar bhi nahi karni bss front grill k andar chali jay.
Bro, hats off for you.
What is current low pressure reading?
Khari gari pe itna hi jay ga. Jab gari chal rahi ho tab aur zyada kum hota ha. Baki yehi best ha jo aap stock setup se le saktay hain sprentine condenser k sath..
Ye pressure idle pe tha naa. Darwazay khulay honay pe... Race denay pe kitna down ata tha?
55-60psi seems bit high to me. Well test it if its cooling is good then keep on using, on hot day like 38-40C.
That's perfectly normal for 32 degree centigrade ambient temperature although the range is i guess 30-47 psi for low side at this temperature but at idle it's a bit high...The idle speed might be low causing that to happen but nothing to worry about if it work's good.
Congo @qazi_sajid i think we can meet up in rawalpindi and you can help explain me this processMa saturday ko ac ka kam krwao ga abhi wo keh re hain kay ap check krwao system kya laga wa hai rwp ma he hai lets see
That will only happen if you intentionally heat the can over 50 degree centigrade i guess the temperature is also written on can. Just avoid placing the can in direct sunlight or away from any heat source you are totally safe..Pehli dafa jab menay ye kia tha to mujhay bhi yehi drr lgg raha tha k abb koi pipe phata, abb can phata, abb compressor gya....
